Intake Manifold!!
Old 04-30-2007, 09:17 PM
SoyMilk's Avatar
Default Intake Manifold!!
Modified by NotAvailable at 5:19 PM 5/3/2007
Old 04-30-2007, 09:54 PM
smileycvc's Avatar
Default Re: Intake Manifold!! (NotAvailable)
Import builders what motor and head your using would really be helpful also what are some specs on your build? Bore? Cams?
Old 04-30-2007, 10:15 PM
SoyMilk's Avatar
Default Re: Intake Manifold!! (smileycvc)
same thing as your sig , what did you use!?
Old 04-30-2007, 10:36 PM
SoyMilk's Avatar
Default Re: Intake Manifold!! (JJSpecTuning)
can u explain to me why blox instead of sk2
Old 04-30-2007, 11:00 PM
smileycvc's Avatar
which one in my sig the b20 or the b18? I actually used a b16 head on both and ran the manifold on just the b18. I ordered the manifold for the b20, but blew up the motor before I installed it. I have the flatest torque curve I have ever had on any of my motors and i really believe the manifold had alot to do with it.
Old 04-30-2007, 11:36 PM
SoyMilk's Avatar
b20 , and what manifold do you suggest sk2 pro or blox with a b16a2 head
or should i just keep the b16 iM??????
Old 05-01-2007, 03:49 AM
92ehatch's Avatar
i can tell you right now, i have a skunk 2 manifold.
its on a d series (doesnt matter)
anyways the car wont idle for **** and ive seen sooooo many threads on here saying the same thing.
i would get something other thank sk2
Old 05-01-2007, 03:59 AM
turbociviccoupe's Avatar
Default Re: Intake Manifold!! (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">i can tell you right now, i have a skunk 2 manifold.
i would get something other thank sk2</TD></TR></TABLE>
ive never had a problem with skunk 2 not idling. it should run like a stock manifold. but sk2 isnt the best mani out there either
Old 05-01-2007, 04:09 AM
92ehatch's Avatar
Default Re: Intake Manifold!! (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">ive never had a problem with skunk 2 not idling. it should run like a stock manifold. but sk2 isnt the best mani out there either</TD></TR></TABLE>
some get it to work well, some dont. anyways.
ive heard good things about the edelbrock victor x
Old 05-01-2007, 04:14 AM
ive heard good things about the edelbrock victor x</TD></TR></TABLE>
thats a good manifold. id prefer that over skunk2 anyday
Old 05-01-2007, 08:28 AM
smileycvc's Avatar
All these are good manifolds, but you will see a flatter torque cure and way more low end torque with the IB manifold. I recommend the IB manifold all day to people going NA.
Old 05-01-2007, 09:00 AM
jus_spooln_wicha's Avatar
AEBS makes an intake manifold for b series.. (its destinctive) it looks like a skunk2 but has splines running along the top.. this manifold i feel is the best as far as air flow.. ive got it on my gsr and it idles fine and the difference is amazing..
http://www.tunerschoice.com/xq...t.htm
Old 05-01-2007, 09:04 AM
Luserkid's Avatar
Great manifold for big builds, not little builds like this he might actually loose power that could be made. I dont suggest the victor x or performer x on anything lower then 12.5 c/r
Go with either the skunk2, blox, or ported ITR, or regular ITR manifold. If you want to go bigger on the compression and the power then upgrade to the bigger manifolds or even ITBs
Old 05-01-2007, 09:06 AM
Ek Forever y0!
Libertariat's Avatar
Default Re: Intake Manifold!! (Luserkid)
Intake manifold Shmintake Shmanifold, Run individual throttle bodies.
vtec8200
17
10-03-2009 07:40 AM
SONAMBULO
01-22-2008 02:14 PM
irideslammed5021
06-09-2007 07:46 AM
Rocket
09-20-2002 07:43 AM
Quick Reply: Intake Manifold!!
