obd 1 sohc d15b vtec swap
Old 11-21-2008, 03:17 PM
zenon8890's Avatar
Default obd 1 sohc d15b vtec swap
hi guys, i'm getting a full d15b swap, does all d15b vtec engines comes with LSD tranny, or it is optional?! if its optional, how will i know from outside?!
thanks
Old 11-21-2008, 03:18 PM
Mr. Badwrench
boostedcivicsir's Avatar
look through the axle hole. if you see a pin its open, if you can see srtaight through its lsd.
Old 11-21-2008, 03:23 PM
zenon8890's Avatar
ok then the LSD is optional right?!
Old 11-21-2008, 05:34 PM
Seagull Management
94EG8's Avatar
Optional and rare.
Old 11-21-2008, 09:05 PM
coupej1's Avatar
my friend ordered a obd1 dohc zc swap and was lucky enough to get the lsd trans with it.
Old 11-21-2008, 10:47 PM
vdawg559's Avatar
once u swap da car let me know if its faster den a regular ex, si single cam 92-95
Old 11-22-2008, 06:19 AM
coupej1's Avatar
my brother has a 95 dx coupe with a d15b vtec swap and a friend has a 94 ex coupe with one also and my d16z6 in my 95 ex was faster then both. They are very reliable motors tho.
Old 11-23-2008, 01:28 AM
vdawg559's Avatar
can u find out what head stamp code u got?
Old 11-23-2008, 03:02 AM
tazeat's Avatar
Should be about the same....
TO OP: Make absolutely sure it does NOT say vtec-e, been there done that, my car is slower than my z6 before it blew now... But it runs great and gets great mpg
Old 11-23-2008, 09:06 AM
RedEG8's Avatar
where can i find the thread for the complete d15b vtec swap
im planning to do it...
Old 11-23-2008, 03:21 PM
vdawg559's Avatar
i forgot i was reading it up somewhere, dat some 92-95 civic si, ex, have differance cams. that are bigger, an wilder...
Old 11-23-2008, 04:51 PM
JDM_SOHC's Avatar
my 94 d15b'd coupe got off on any ex i ever raced all motor, even took some LS's and SI's... i had every bolt on you could have but still, a lot goes into whos driving the car also... than i went turbo, and had no problem beatin bout 90% of the cars i raced...
JDM_EJ8
11-15-2011 08:49 AM
eg6ajk
109
06-12-2011 02:52 PM
yakitori
12-01-2003 12:22 PM
nijia555
11-29-2003 06:32 PM
yakitori
11-18-2003 02:48 PM
Quick Reply: obd 1 sohc d15b vtec swap
