o2 sensor????
o2 sensor????
this may be a dumb question but do you have to have the o2 sensor hooked up in order for the car to start?? i can not figure out why the car wont start?? i have a 92 civic and putting a b18b1 in it!! can you help me out .. Also do i need to use the b18b's computer or can i stick with the 92 civics computer??
Re: o2 sensor???? (1988_96hb)
Correction: The car will run just fine without an o2 sensor or a working one. You will notice a slight decrease in MPG/performance, that's about it.
Oh, along with a C.E.L. on the gauge cluster.
Re: o2 sensor???? (mikester1222)
Oh, you definately need the b18b's ECU to run the motor, NOT the original one. You're no longer using that motor, so you need to also swap the ECU's.
