not starting....
Old 08-09-2005, 09:05 PM
sLoWrAcEr's Avatar
Default not starting....
i have a jdm b16a in my 1993 si hatch....i was racing unfortunatly and all of a sudden a loud backfire happend my tach went all bizzurck...then it was smoking...then it wouldnt start up....i pulled the ecu fuse and then put it back in.....it starts....i try to move and it bucks very hard....no oil leaks...oil level is good...opened the radiator cap and it was a lil foamy.....reg. 50/50 mix.....what could be the problem.....yea i have CELs for TPS O2 ....please help me find out what happened!!!
Old 08-09-2005, 09:10 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: not starting.... (sLoWrAcEr)
Smoke from where?
What do you mean by "my tach went all bizzurck"?
Sounds like an ECU/wiring problem maybe, but need more details...
Old 08-09-2005, 09:13 PM
sLoWrAcEr's Avatar
Default Re: not starting.... (JDM_Ej)
smoke just under the hood couldnt see from where tach was jumpin from 1000 to 5000 rpms......i dont know
Old 08-09-2005, 09:18 PM
sLoWrAcEr's Avatar
i was thinking distributor......yay or nay
Old 08-09-2005, 09:29 PM
sLoWrAcEr's Avatar
someone help please
Old 08-09-2005, 11:57 PM
sohc1200cc's Avatar
check your oil cap and radiator cap for oil and water mixure.. if it has some deposits your head might have warped.. if it warped you need to re-shaved or put a new head for your engine bay.. if it has no deposits check your distributor of it gives out electricity for your spark plug.. check the timing mark of your cam gear and crank if it is on the correct timng marks..
Old 08-10-2005, 10:05 AM
sLoWrAcEr's Avatar
Default Re: not starting.... (sohc1200cc)
i pulled my valve cover this morning and there is no sludge...i pulled the radiator cap and it was foamy... ....checked the spark plugs they are black....too rich.....any ideas...?
Old 08-10-2005, 10:29 AM
sLoWrAcEr's Avatar
up for answers
Old 08-10-2005, 11:34 AM
sLoWrAcEr's Avatar
cmon honda tech damn i know this has happened to someone!
Old 08-10-2005, 08:24 PM
sLoWrAcEr's Avatar
ugghh damn.....cmon anyone? last call
Old 08-12-2005, 09:35 AM
sLoWrAcEr's Avatar
ok im throwing the ignition output signal code....whats that....new dizzy???
Old 08-15-2005, 10:49 PM
sohc1200cc's Avatar
better check your dizzy first!! coz the tach is connected to the wiring of the dizzy!! if it went berzerk that maybe your problemo..
Old 08-15-2005, 10:50 PM
sohc1200cc's Avatar
don't uoy think that you have a blown engine?
Old 08-16-2005, 09:37 AM
sLoWrAcEr's Avatar
it could possibly be blown....but i think its the dizzy.....any cheap places? suggestions?
PhantomX
11-29-2008 11:03 AM
corchado85
05-26-2007 09:44 AM
copsloveme
12-03-2006 02:11 PM
Calavera
01-27-2004 07:10 PM
Dr. Gonzo
02-03-2002 09:58 AM
Quick Reply: not starting....
