Is this normal when you chang clusters?
Is this normal when you change clusters?
I had a ctr cluster in my car and it worked fine. I took it out and put in a si cluster. I believe when I put it in the gas needle was at the bottom. When I put it in and started the car it moved up to the full position. Is this normal? I let the car run for a while and it didnt drop. Any suggestions?
I think the cluster is bad, look at the back of the cluster, make sure nothing is burnt out. I had a cluster that burned out somehow and my tach didn't work.
Re: (Hanmin)
well it did move up its just reading wrong. Im going to take the clear cover off and push the needle down and see what happens
Re: (sageuvagony)
well it was a trade. Si cluster + cash for my ctr cluster but before I send the ctr i need to make sure the si cluster works
Re: (Burnt Toast)
nah im not pulling the needles off, there is always a chance they will break, if it dont fix itself Ill just send his money and his cluster back
sf@rx7
02-17-2006 07:42 PM
trooper0641
09-01-2004 11:13 AM
