Is this normal?
Is this normal?
This is my tranny mount, should there be a gap like that from the rubber to the metal?
It isn't worn or anything, looks like it came like that. I don't remember, but I'm pretty sure that is a mount from my stock engine which the b16b coincidentally fit in.. Can one of you b-series junkies check your mount to see if it's different?
two of them are brand new..
Somebody told me to put a little bit of locktite on the lug bolts to help keep them on, but all 16 lugs are always tightened to 80 ft/lbs and this is the only wheel having problems. I'm just trying to figure out what could be causing it instead of temporarily band-aiding it.
Re: (Emerika)
Torque them down to 80ft, go aroudn the block and retorque them. Sometimes theyll come loose.
But yes what Emerika said could also be true, are they aftermarket rims, is everything centered on the hub and level?
Also your crossing them right?
Re: (blaster834)
the mount is fine...spend 30 bucks and get the energy suspension inserts, I did and my motor is rock solid now no torqueing at all, vibrates a lot at the light but runs firm down the strip.
for the lug nuts, does the that side vibrate at all as you drive, Ive seen a hub with bad bearings wiggle a tire loose on the track, fucked up his studs and rim.
what ever you do...DO NOT LOCKTITE YOUR ****! if youve ever drilled out a stud you dont want to do it ever again. (split a allen key lug nut!)
