noise while turning
Re: noise while turning
Put the wheel back on, jack it up, and grab it at 12/6. Try to move it. Now grab at 3/9, and do the same. If it moves from 12/6, you have bad ball joints. If it moves from 3/9, you have bad tie rods and/or tie rod ends. If it moves in all directions, it's either ball joints, tie rods/ends, or wheel hub bearings.
Also, remove your brake pads and check for abnormal wear on the pads, as well as the rotors.
What kind of noise is it? Clicking? Rubbing? Grinding?
00ekcoupe
08-16-2006 12:27 PM
Spence
Suspension & Brakes
07-18-2005 03:38 PM
