no heat please help
Old 12-15-2010, 10:17 PM
  #26
hatchet_honda's Avatar
Default Re: no heat please help
hmmm ok sooo the air DOES blow out right? were talkin bout the blower blowing COLD air that only gets LUKEWARM? thermo replaced...both hoses warm...air comes out on the floor not the dash? i too would x2 on the heater core being clogged. try a flush and see what happens.
Old 12-15-2010, 10:19 PM
  #27
Originally Posted by jdm36
the blend door is working ive checked that. it does seem like the heater core is new cause everything under there is new but also if the motor is even cold there is some pressure that comes out of the radiator.
what do you mean everything under there is new? makes no snese..you wouldnt be able to see the heater core. its inside the air box. it appears clean or something you mean??
Old 12-15-2010, 11:01 PM
  #28
jdm36's Avatar
well i dont know if the heater core is new thats just what the guy told me that i bought the car from.About the new under the dash i was talking about the blower motor and the tubing that goes to vents now if both hoses going to the heater core are warm wouldnt that mean the heater core would be fine.
Old 12-16-2010, 09:32 AM
  #29
it still could be clogged...coolant still passing thru but not enough to make hot air
Old 12-17-2010, 06:59 PM
  #30
jdm36's Avatar
so i took the water control valve off and bought one of the flush kits and put the tee place of the valve to see if that would do any thing but still nothing.
superninja
Honda Civic (2001 - 2005)
10
12-23-2021 05:05 PM
shortycm17
03-26-2008 05:33 PM
crxricer66
12-10-2007 04:41 AM
s1ngle
12-12-2005 05:26 AM
delSolLS
01-16-2002 01:06 PM
Quick Reply: no heat please help
