No dome light or AC lights; door locks work sometimes
Old 08-11-2015, 12:01 AM
civicboy420's Avatar
Default No dome light or AC lights; door locks work sometimes
Like the title says, its for my 98 Civic EX. Interior light fuse is good, bulbs are good. No aftermarket stereo. Thanks in advance.
Old 08-11-2015, 04:41 PM
Former User's Avatar
Default re: No dome light or AC lights; door locks work sometimes
Do you mean climate control lights? Do the cluster back lights work?
The dome light fuse is under the hood.
Old 08-11-2015, 07:53 PM
Sorry climate control light and I know where the dome light fuse is it's good. Cluster works fine.
Old 08-13-2015, 05:09 PM
Bump anyone else know?
Ron j no replys? Am I just screwed or what? It takes forever to get an answer!
Bump bump bump are you freaking kidding me?
Old 08-15-2015, 05:04 AM
How do you know?
Old 08-16-2015, 01:49 PM
Because I checked it that's how I know
Old 08-16-2015, 01:58 PM
I never narc'd on nobody!
NotARaCist's Avatar
Before you decide to be a smartass...
What RonJ is asking, is HOW did you check it? We've all grown tired of people constantly wasting our time. You're going to have to give us these things called details if you want any help.
Old 08-19-2015, 05:28 AM
Default Re: No dome light or Climate control lights
Lol I popped the hood, opened the fuse cover and pulled out the fuse marked "interior light"
Old 08-19-2015, 08:04 PM
NotARaCist's Avatar
<p>And that is exactly why RonJ asked. &nbsp;That's not the correct way to check a fuse. &nbsp;Get a voltmeter, set it to resistance, and touch the leads to the two small bits of exposed metal on top of the fuse. &nbsp;You don't need to remove it. &nbsp;If it has resistance, it's failed.&nbsp; That's how you properly test a fuse.</p>
Old 08-25-2015, 09:59 PM
Thanks for the response. I opened my sunroof and my dome light came on. Wierd. I decided to smack the climate control and the light came on, until I flipped the location switch then off it went. Possible wiring problem? Thanks again.
Old 08-31-2015, 08:22 AM
Bump
Old 09-02-2015, 05:43 PM
Default Door locks work sometimes
My 98 civic door locks aren't working properly. When the car is running they open and close fine. When car is off they stick. Could it be my solenoids?
Old 09-03-2015, 04:40 PM
Default Re: Door locks work sometimes
Bump helllllooooo?
Old 09-03-2015, 05:56 PM
Jimi Hondrix's Avatar
One difference between the car running and not is voltage: https://honda-tech.com/audio-securit...nning-2573400/
Remove your door panel(s) and disconnect the actuator terminal.. use a multimeter to check voltage on the supply side of the terminal while car is off and on and in lock/unlock (switch position). Read up on how to test the actuator voltage.
Don't think the locks has solenoids.. it has actuators in the doors but, from what you described it doesn't seem like they are the issue. Also it would be rare to have all the door actuators going bad at the same time.
Another possibility is (since all doors are having the issue) is the central door lock module ..blue box located in driver's door about a foot above speaker. Not sure how to test that module.. but, easy enough to pull one from a junk yard and try it.
image of blue box: http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/2mQAAMXQVERSxYH4/$_35.JPG
Old 09-04-2015, 03:52 PM
Thanks Jimi I will try one from picknpull.
Old 09-07-2015, 09:18 PM
datndat's Avatar
Default Re: door locks work sometimes
Have a 99 civic sedan. Door locks works on and off.
Civic Racer X 7
08-25-2012 05:55 AM
mickeey
03-11-2009 07:18 AM
reefranger
10-02-2005 02:54 PM
SLOAZZ95
10-06-2003 11:55 AM
Quick Reply: No dome light or AC lights; door locks work sometimes
