Nitrous fuel upgrades
Current Mods:
1995 d16z6
i/h/e
aem cam gear
msd ignition
Plan on spraying 75 shot with the following upgrades: fuel pump, regulator, filter and maybe some 270cc injectors tuned with Hondata.
Besides colder plugs, what else do you guys recommend?
1995 d16z6
i/h/e
aem cam gear
msd ignition
D Tranny Guru
Re: Nitrous fuel upgrades (1zexxedcivic)
What kit you using???????
My rundown.......
ZEX at 85 shot, 325 cc/min injectors, MSD 6AL, Champion plugs. Normal fuel sysytem upgrades also.
Cam gear is not really needed. Use it to retard the cam 2-3 degrees to lessen the cylinder pressure below 5000 rpm under juice.
My rundown.......
Re: Nitrous fuel upgrades (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote"> Champion plugs</TD></TR></TABLE>
Hey Mista Bone, Why do you use the Champion and not the NGK's?? Any difference.
D Tranny Guru
Re: Nitrous fuel upgrades (97hb)
Champions don't melt the ground strap as easy...........
ZEX at 85 shot and LEAN!!!!!!!!!!!
Learn to read the heat stripe......
Re: Nitrous fuel upgrades (WiDeBoDyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK »</TD></TR><TR><TD CLASS="quote">ive been running zex plugs for as long as ive been running nitrous (2 years) and ive had no problems with them</TD></TR></TABLE> good to hear. i just got the zex plugs for my nitrous setup. theoretically they should work cause they were designed by zex for nitrous/turbo to prevent detonation.
