New Help Troubleshooting Radiator Fan
I have a 1994 Del Sol S and the radiator fan does not kick on. I have replaced the fan, check the fuse inside the car, checked the fuse under the hood and swapped out the relay. Is there any other tips anyone might be able to provide.
Also, does anyone know of an easy way to make sure the fan should turn on besides driving the car to get it to heat up? When should the fan turn on -- at start up or when the thermostat guage reaches (half-way, 3/4s, etc.)?
Thanks.
Thanks.
Re: New Help Troubleshooting Radiator Fan (RonP)
Where the fan wires plug into the relay (Right behind the thermostat). Take a small piece of wire stick it in both plugs just like a jumper wire. Then the fan should kick on when u start the car or even turn the key on..........Hope This Helps
dudeomega2000
01-06-2008 09:51 PM
ShinotakuX
12-14-2007 08:20 PM
wsiracerz
10
06-04-2004 12:47 PM
