new eg hatch (my build thread)
Old 04-14-2012, 01:16 PM
andypwnz's Avatar
Default new eg hatch (my build thread)
B18B1 swap (1,500 miles on rebuild)
complete type R internals, 12:1 compression
itr crank
one piece header
AEM fuel rail
B16 trans with stage two clutch and lightweight flywheel
all new gaskets, new water and oil pump
front camber kit, new upper and lower ball joints, new inner and outer tie rods
new struts and adjustable coil overs all around
almost new Si seats
GSR read disk swap
when i bought it, he wouldn't part with the hood so i just put on one from the junk yard. theres a few things she needs and i have a whole slew of parts on the way. all the body work is done and as you can tell, she's just primer but i took college auto body so its no big deal to paint a car for me.
i'm off at college right now and the car is currently at home but everything should be waiting for me when i get home this weekend so i should have updates then.
enjoy,
Old 04-14-2012, 01:21 PM
andypwnz's Avatar
Default Re: new eg hatch (my build thread)
i also have a couple questions here:
1. the ebrake doesn't have a cable attached at all, the guy says its because with the swap theres not really any brake cable thats like "made" to fit
theres gotta be a way to get them to work if anyone knows how
2. my buddy has a everything i would need to turbo her, but thats probably not a good idea running 12:1 compression. right?
-thats all i got off the top of my head, thanks guys
Old 04-14-2012, 06:34 PM
Steezer's Avatar
Im pretty sure the engine swap has nothing to do with the E brake cable. The GSR rear "swap"/conversion might have something to do with it.
How much did you buy this car for?
Old 04-14-2012, 06:50 PM
Bradshaw's Avatar
by swap i'm thinking he means his GSR rear disc swap.
Old 04-14-2012, 07:26 PM
Nickeg9Ej1's Avatar
94-01 integra e brake cables fit like they were supposed to be there, he probably didn't get them with the rear trailing arms and did the swap anyways.... high compression turbo can be done very well as long as the tuner is good at his job. low compression is a lot more common due to the fact that they dont detonate as easy.
Old 04-14-2012, 10:34 PM
andypwnz's Avatar
i got her for 3700. not bad considering i live in illinois and its RARE to see an eg hatch with no cancer
also the PO said he had 8 grand in the motor lol
by swap i mean GSR rear disc swap, i figured that was self explanatory
thanks for the input nick, i'll go pick up that cable as soon as i can here, i'm thinking you mean the 2 door integra. right?
and i know of a shop about two hours away thats really expensive, but the tuner is really good.
i had an 88 crx, it was my first car. but i knew the d16a6 like it was nothing, lol i think i had the motor out of the car more often than it. this whole b series deal is like a different world though
Old 04-14-2012, 10:41 PM
egsleepercivic's Avatar
you could use 92-95 si ebrake cable since it has the same rear brakes stock
Old 04-15-2012, 12:08 AM
andypwnz's Avatar
thanks, i'll remember that as i scour countless junk yards
also, is it fairly straight foreword where the cable attaches to the brakes?
sorry, i've never had rear discs but i can't imagine it being very different compared to front discs
Old 04-15-2012, 12:29 AM
jbpnoman's Avatar
Yes, it's fairly straight forward. The piece on the end of the e-brake cable will fit perfectly into the piece on the caliper, and not only are they both plainly visible, but they will obviously look like they belong together.
12:1 and turbo can work great, but it can also grenade a motor faster than a Barrett. If you decide to do it, either install the turbo and have the car towed to the tuner (do NOT try to drive it there, even on a basemap) or ask the tuner how much it'll cost to have him/her do the install for you. Either way, 12:1 and boost should NOT be driven, period, until it's tuned correctly. Unless you like a nice, big, expensive paperweight.
Did he say exactly what that 8 grand was in the motor? He could have obscenely overpaid for all of his parts, or he could have been a damn good shopper and built a pretty solid little motor. More details, if you have them, would definitely be beneficial here.
Old 04-15-2012, 11:32 AM
andypwnz's Avatar
type r pistons, itr crank, type r cams. he did a full rebuild and said everything he got was type r lol thats all i really know
Old 04-15-2012, 07:01 PM
Hardrath_R's Avatar
Damn 8 grand? I have a b18c type r fully rebuilt with Skunk 2 internals and it cost 4 grand including parts, and labor.
Old 04-15-2012, 08:01 PM
andypwnz's Avatar
thats just what the dude i bought it from said
one of these days i'll open her up and take some pics of the inside just to see
some how, it sounds like theres a super charger, i have no idea why but it has this nice whine when hit the gas
Old 04-15-2012, 09:40 PM
anothersickhatch's Avatar
It's most likely the timing belt. My sounded like that as I liked to have my belt on the tighter side.
On another note, it looks like that is a non-VTEC head. How do you have Type-R cams? Am I missing something here?
Old 04-15-2012, 09:45 PM
jbpnoman's Avatar
So basically, he's an R fanboi who didn't shop around, and paid entirely too much for everything. Gotcha.
Old 04-15-2012, 09:54 PM
andypwnz's Avatar
lol guys i have no idea, like i said: i'm in college and i'm not going home till next weekend
when i get back home (where the car is) i'll take off the valve cover and check it out, then go from there.
Old 04-16-2012, 03:10 AM
Well, I can tell you right now that that motor does not have Type-R cams. Or any VTEC cams for that matter.
Old 04-16-2012, 04:02 AM
Resident Gearhead
BryanM.'s Avatar
Good start man. Pics are a little small though.
1. I'm almost positive you can't install VTEC cams in a B1 head
2. This engine is incapable of having VTEC as it is now
3. ITR crank, rods and pistons will NOT make 12:1 compression
The guy you bought this car from is absolutely full of ****. I wouldn't be surprised
if that is a completely bone stock B18B1 from the valve cover to the oil pan.
Rebuild? New oil pump? 8 grand? Yeah right...
Old 04-16-2012, 04:06 AM
Resident Gearhead
BryanM.'s Avatar
OP please post a pic of the front of the transmission where it meets the block.
Old 04-16-2012, 06:29 AM
jdmej1civic86's Avatar
looks good keep it up
Old 04-16-2012, 10:48 AM
mikeCentola's Avatar
looks great! love the valve cover
Old 04-16-2012, 11:15 AM
andypwnz's Avatar
well its not stock, i know that much. its too quick to be stock.
Old 04-16-2012, 11:16 AM
andypwnz's Avatar
i'll get that pick of where it says what the motor is this weekend too
Old 04-16-2012, 01:22 PM
It's possible that it feels quick because it has a b16 transmission. Don't get me wrong, it may have a decent amount of "get up and go", but for 8 grand, it should be making loads of power. As long as you are happy with the car, that is all that matters. In my opinion, the seller was most likely full of it.
Old 04-25-2012, 05:08 PM
andypwnz's Avatar
some more pics
Old 04-25-2012, 05:09 PM
trashyhatch's Avatar
cannot take srs due to 'dubstep' bracelet.
Quick Reply: new eg hatch (my build thread)
