Need Water Outlet Gasket Information
I was wondering if anyone knows how you seal up the following part for a B16a head. I checked http://www.hondaautomotiveparts.com and it doesn't list any gasket for it. Here are pics of the part I need a gasket for and it is Number 6 in the diagram:
Description: COVER, WATER OUTLET
Diagram:
Pictures:
Thanks.
Diagram:
Pictures:
Thanks.
Re: Need Water Outlet Gasket Information (untuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untuned »</TD></TR><TR><TD CLASS="quote">just put some hondabond on it, you'll be ok</TD></TR></TABLE>
Yeah, it looks like it was sealed previously with Hondabond.
Re: Need Water Outlet Gasket Information (dwnthehatch)
Yeah it was barely sealed previously as it leaked slightly. I don't see why there isn't a gasket of some kind since it is metal to metal contact.
Re: Need Water Outlet Gasket Information (King Tut33)
clean off the surface of the water neck...and its mating surface
and put a coat of hondabond on...u should be good to go
Guest
Posts: n/a
Re: Need Water Outlet Gasket Information (Dan GSR)
Hondabond.....just a film layer. Clean both surfaces with a razor blade to remove any remnants. If you put too much on, the mating surfaces will be uneven and it will leak.
I used a razor blade to spread the hondabond evenly across the surface before mating, probably 1mm thickness or less is needed.
Ohmster
07-04-2008 09:52 PM
SECURITY
18
07-28-2005 10:21 PM
