Need some help Swapping out a 2000 civic tranny
Hey guy's, my friend need's her transmission replaced on her 2000 civic ex, it is an automatic, ive never removed a transmission and was wondering if anyone here can tell me the steps to doing it. Ive looked up diy's and cant find anything for an automatic transmission.
Technical Hero
Re: Need some help Swapping out a 2000 civic tranny
Your best bet is to google and download the civic factory service manual, here are the steps without pics
http://garageninja.com/automatic-tra...TransmissionEg
No harder then removing a 5mt just have a few more things to unclip ie: shift sol plug trans cooling hoses to rad. and any d-series auto trans should work afaik.
no it won't....what ever point the ECU tells it to shift at that's what it will do. the trans it's self could care less what point it shifts up/down. Don't know were you heard that that's like saying raising the VTEC engagement point will set off a CEL.
I'm not 100% on Honda autos but I know GM auto computers are very sensitive and will get pissed off very quickly if the VSS signal and trans input shaft speed don't jive with what the ECU is expecting.
So my advice to the OP, get the proper tranny for the car.
Also factory service manuals are available at shweet.org.
If you loved me, you'd all sell me your magic cards to me today
I never narc'd on nobody!
The TCU is integrated into the ECU. Using an LX auto in an EX will throw a shift solenoid malfunction light, and may also throw a torque converter lockup light. If you use an LX ECU, your car won't run correctly at all. When replacing automatic transmissions, you must match gear ratios, which means matching chassis codes.
Fish Twig
You're wrong. You've been proven wrong about this.
MntlKase
11-17-2011 11:49 AM
