need some help
Old 12-01-2007, 11:17 AM
umair's Avatar
Default need some help
i was driving my car today and noticed that the belts started to squeak right when i pulled over the battery light came on. i opened the hood and saw that the power steering belt was not on(it was starting to eat away) and the alternator belt went behind the crank pulley. i tried to put the alternator belt on but only half of it got on. i cranked the car and it got back on and drove home with no problems. what would cause something like this to happen?
does this have anything to do with it? this happened about 1000 miles ago but the car has been running fine.
i hope this is not the problem.
Old 12-01-2007, 11:22 AM
Davis Photography
DrewMD's Avatar
I would check the tensioning on the belt. If it was loose, I could see it sliding off like that.
Old 12-01-2007, 11:53 AM
JDM_Frijoles's Avatar
Default Re: (DrewMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewMD &raquo;</TD></TR><TR><TD CLASS="quote">I would check the tensioning on the belt. If it was loose, I could see it sliding off like that.</TD></TR></TABLE> X2
Old 12-01-2007, 12:25 PM
umair's Avatar
but why would they come off at the same time? but i will tension them some more.
Old 12-06-2007, 02:09 PM
umair's Avatar
bump!!
Old 12-06-2007, 04:23 PM
instrument's Avatar
i have no idea what we're supposed to do with the picture and info you posted.
is that a robotic nipple?
Old 12-06-2007, 04:25 PM
umair's Avatar
that is the crank(the part where the key goes)
Old 12-06-2007, 04:27 PM
blk92_d16's Avatar
Make sure the crank isn't wobbling and that the crank bolt is TIGHT! Then adjust the accessory belts...
B20vEf9
06-29-2010 09:45 AM
dj-t
06-25-2009 08:21 PM
tigueremalo
01-24-2007 08:10 AM
flatblack-h22
08-17-2006 05:53 PM
R6E6I6D
05-13-2005 07:18 PM
Quick Reply: need some help
