Need quick help with 1 radio wire...
Old Feb 15, 2011 | 12:54 PM
6KAOS6's Avatar
Icon2 Need quick help with 1 radio wire...
My 92 civic vx that I just got had no radio in it and the wire connector was cut off... So I did a search on here and got the wire diagram. I have 1 wire left from the car: "RED/BLK= Illumination" and 1 wire from the stereo connector: "BLUE= Remote turn-on or Power Antenna"
Should I connect the 2 wires? OR Tape 'em off and leave 'em un-connected?
Thanx
Old Feb 15, 2011 | 12:56 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Need quick help with 1 radio wire...
Do NOT connect them.
Old Feb 15, 2011 | 12:59 PM
6KAOS6's Avatar
K, Now will I have Illumination on the radio? Since the factory Illumination wire isn't hooked up?
Thanx
Old Feb 15, 2011 | 01:17 PM
b16a1eg6's Avatar
Aftermarket radios have backlighting that comes one when the red wire is powered
Old Feb 15, 2011 | 01:37 PM
6KAOS6's Avatar
So, I left those 2 wires alone.. Plugged in the ant. and plug to the radio. And I get NO power NO nothing.... The only thing that was diffirent from the wiring diagram that I got on here was: 12v constant blue/white, BUT on my car I didn't have that wire I had a white/blue wire. So, I used that as the 12v constant...?...
Old Feb 15, 2011 | 01:53 PM
The Grumpiest
How do you know the wire you used was for 12v constant? By guessing randomly like that you could possibly destroy your new deck.
Old Feb 15, 2011 | 02:00 PM
6KAOS6's Avatar
I hooked all the other wires up 1st. Then I had 2 wires left: red/blk, wht/blue.. The diagram stated that the red/blk wire was the illumination wire. So, The wht/blue had to be the 12v constant..
Atleast thats what my logic was...
Old Feb 15, 2011 | 02:03 PM
The Grumpiest
Apparently you guessed wrong. If I were you I would go to a junkyard and get the matching plug that was cut off and re-wire everything. Then go and buy a proper wiring harness to hook everything up.
Old Feb 15, 2011 | 02:07 PM
Project Dad's Avatar
usually power wires are red or yellow. as for constant 12v if i recall correctly they are the yellow with a fuse. but not always.
as for that blue wire "remote turn on" that would be the wire to an amp
Old Feb 15, 2011 | 02:36 PM
drod's Avatar
the yellow wire coming from your aftermarket deck is the constant power, red is ignition power. the blue one is for running to an amp if you have one
Old Feb 15, 2011 | 02:40 PM
The Grumpiest
I don't think the new deck is the problem.
Old Feb 15, 2011 | 02:44 PM
6KAOS6's Avatar
what is the wht/blue wire from the car?
Thanx
Old Feb 15, 2011 | 06:19 PM
ZacinStLouis's Avatar
Blue/White is constant power for the tuning memory. Yellow/Red is the power wire for the stereo.
Old Feb 15, 2011 | 06:23 PM
Former User's Avatar
Constant power = Wht/Blu wire from fuse 32
Ignition switch power = Yel/Red wire from fuse 23
Illumination wire = Red/Blk wire from fuse 19
Old Feb 15, 2011 | 10:53 PM
6KAOS6's Avatar
RonJ@HT: Where is fuse 32 located?
Old Feb 16, 2011 | 04:48 AM
It's labeled Back Up fuse (7.5A) on the lid of the hood fuse box.
Old Feb 16, 2011 | 07:31 AM
6KAOS6's Avatar
Thanx for the help, all is workin'..
Old Feb 17, 2011 | 12:11 PM
Blacknight117's Avatar
I`m having the same issue, but I check all my wiring with the new harness for my unit, and it`s not turning on. I checked all the fuses, I even replaced the old ones with new ones and I`m still not having any luck...
Old Feb 17, 2011 | 12:24 PM
The Grumpiest
If the old deck worked then you have something mis-wired. If you're using an aftermarket plug-n-play harness then it should work with no issues.
Old Feb 17, 2011 | 12:26 PM
I just tested the harness, and I`m only getting 4.5V. Has to be the harness, no? And my unit is aftermarket.
Old Feb 17, 2011 | 12:27 PM
The Grumpiest
The stock harness or the aftermarket? Did the old deck work?
Old Feb 17, 2011 | 12:36 PM
The stock deck worked before I took it out. Than, I spliced the aftermarket unit`s harness to the stock harness and connected the aftermarket stereo. Than I tried to turn it on and it didn`t, I checked my wiring, all checks out. Than I tested the constant 12V wire on the stock harness and I`m only getting 4.5V...
Old Feb 17, 2011 | 12:37 PM
The Grumpiest
Are you using one of these?
http://www.techronics.com/caraudio_1...html?aff=72182
Also check this link.
http://www.installdr.com/installdocs/honda/civic.asp
Old Feb 17, 2011 | 12:38 PM
The Grumpiest
So you cut the harness wires? Still sounds like you mis-wired things if you're not getting power.
Old Feb 17, 2011 | 12:48 PM
This is harness that came with my aftermarket stereo.
http://i721.photobucket.com/albums/w...-43-05_531.jpg
Yes, I cut the stock harness so I can splice the new harness to the stock harness. Yes, I`m an idiot i know, But I wasn`t thinking at the time. But I checked the site you gave me, thanks btw, and everything is where it`s suppose to be.
