need more info on oil leak problem...
ok i got a massive oil leak and ive done replaced the valve cover gasket and the oil pan gasket and the rear main seal gasket..... Im guessing its the damn oil pump but need to know if that could be a problem and is there anywhere else oil could leak from before i start take a look a the oil pump..? any info would help..
Re: need more info on oil leak problem... (GSR_hatch936)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 »</TD></TR><TR><TD CLASS="quote">ok i got a massive oil leak and ive done replaced the valve cover gasket and the oil pan gasket and the rear main seal gasket..... Im guessing its the damn oil pump but need to know if that could be a problem and is there anywhere else oil could leak from before i start take a look a the oil pump..? any info would help.. </TD></TR></TABLE>
my suggestion to you is clean your motor. clean it really good. once all the oil has been removed then periodically check on the motor. eventually the motor will leak again, with it being clean it will be alot easier to spot.
to ask us to figure it out with out see the car is impossible. all we can do is speculate, and even then we can be wrong.
yea ive done that but i looks like it leaks right where the engine and tranny meet but like i said i checked or replaced everything around there and the oil pump is the only other thing that i can think of.... dont wanna take it off if its a easyer thing to replace or somthing else..
Re: (GSR_hatch936)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 »</TD></TR><TR><TD CLASS="quote">yea ive done that but i looks like it leaks right where the engine and tranny meet but like i said i checked or replaced everything around there and the oil pump is the only other thing that i can think of.... dont wanna take it off if its a easyer thing to replace or somthing else..</TD></TR></TABLE>
if the leak is where the engine and tranny meet, then it's not your pump since the pump is on the opposite side.
have you replaced the distributor seal or o-ring? what about the cam caps on the side? is it a vtec motor?
Re: need more info on oil leak problem... (z6hatchboy)
well it leaks on the bottom of the motor not on the head or around the head.... but i would guess it runs down to where the motor meets??
GDD's Dr. Phil?
Re: need more info on oil leak problem... (cln92eg)
if it is around where the motor meets the trans, and it is not coming from the top, it is most likely the rear main seal...
Re: need more info on oil leak problem... (oneludesol)
ok imma say this again i replaced the REAR MAIN SEAL, OIL PAN, AND THE VALVE COVER GASKETS... and the dizzy isnt leaking i would have know if it was there.. i got a b18c1 (gsr)
GDD's Dr. Phil?
ok, ill say this again... REAR MAIN SEAL. It is the only thing in there that can leak... Maybe you dicked it up when you replaced it. I know I wouldn't let you replace mine.
Re: (oneludesol)
its engine oil cuz i check my engine dip stick every other day an it gets low after bout a week... and then i put more oil. and not its not the rear main seal cuz i put it in there right bro...! thanks anywayz for the info.
Ser1N
01-26-2020 02:26 PM
B16CivicEX
06-22-2006 05:53 PM
