need info on this ecu:37820-pcv-j91-1157-104396
H-T White Ops
Re: need info on this ecu:37820-pcv-j91-1157-104396
37820 designates it as an ECU, but that's about all that's right as far as the US EPC shows.
PCV and J91 don't show for any match to a car in the US at least.
A Honda ECU part number should look something like:
37820-PXX-XXX
The first five digits say what kind of part it is (in this case, an ECU), the next three digits designate the car it's from and the last three to five digits just narrow it further. If it says RM at the end it's a reman.
37820-PXX-XXX
H-T White Ops
Okay, a little more digging shows me that 37820-PCV-J91 is from an overseas 1999-2000 Civic EXi automatic sedan (KU).
That car is an EK3 with a D15Z5 (1.5L SOHC non-VTEC).
Where are you located?
i am in trinidad and tobago.......thanks for the info.....but i gettin alot of trouble to find info on this ecu.....eg pin outs and stuff
H-T White Ops
I couldn't even find a lot of information on the engine.
Seagull Management
is it a 3 or 4 plug ECU? Appears to be an automatic ECU based on the number, if it is a 3 or 4 plug USDM pinout should be the same. If its an oddball 2 plug ECU good luck.
