need help wiring rear wiper motor
ok the car is a 94 cx and i noe it doesnt come wit the floor harness so ima hard wire it to a simple switch so i jsut wanted to noe wat wire is wat there is bascailly 4 wires and im thinking 1 ground, 1 -, 1 +, and one to the swtich then make a comeplete circle? if anyoen has done it and has the rite wiring for it plz help me out thanks again
Re: need help wiring rear wiper motor (kyorishin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyorishin »</TD></TR><TR><TD CLASS="quote">ok the car is a 94 cx and i noe it doesnt come wit the floor harness so ima hard wire it to a simple switch so i jsut wanted to noe wat wire is wat there is bascailly 4 wires and im thinking 1 ground, 1 -, 1 +, and one to the swtich then make a comeplete circle? if anyoen has done it and has the rite wiring for it plz help me out thanks again</TD></TR></TABLE>
tkea da wred bule n grrrreeen wut wth noe nd curnnect itz to da purpel wres n'd BAM!
Try clarifiying your problem into what normal people could read. All I understand is that you are trying to wire up a rear wiper motor but your car doesn't have the harness? What switch are you hooking this up to? A regular switch you bought or to the steering colum?
Re: need help wiring rear wiper motor (old man neri)
sorry i was typing on a labtop... the problem is i dont know which wires coming from the rear wiper do what... i have a green, green/black, black, and blue...im tryin to wire it up to a regualr switch i bought. is that clearer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyorishin »</TD></TR><TR><TD CLASS="quote">sorry i was typing on a labtop... the problem is i dont know which wires coming from the rear wiper do what... i have a green, green/black, black, and blue...im tryin to wire it up to a regualr switch i bought. is that clearer</TD></TR></TABLE>
No worries.
Black like you said is most likely ground. Do any of these wires control the washer fluid nozzle?
Other than that I would try experimenting if no one else can help you. A good haynes should tell you what the wires are.
No worries.
civic_loner22
24
03-18-2011 07:39 PM
Civichatch972
11-18-2003 01:17 PM
