need help with tire size asap
I am wondering what size tires do you guys use on your EK hatches I was looking and it says for, I am wondering is that the correct tire sizes.
1996-195-50-15
1997-195-55-15
Thank you:
1996-195-50-15
1997-195-55-15
Thank you:
Re: need help with tire size asap (grandam)
they way it works out with falken tires is that the stock size should be 185/65r14 and with 195/55r15 it's .7 bigger in diamater and a 205/50r15 is .2 of inch smaller in diamater but is wider thats what i'm running on my ej8 and approx, a 2 inch drop i tuck tire and no rubb issues
Re: need help with tire size asap (t0p_sh0tta)
I am wondering what is the difference between the 96 and 97 aren't they the same car, also these will be going on my EK hatch with a 2.5" drop
Re: need help with tire size asap (98greensi)
Hello so I can use the 205-50-15 and there will be know problem what is the difference between the 205-50-25 and the 195-55-15 and also if I use the 205-50-15 will the car be higher off the ground compared to the 195-55-15.
Thank you:
Mark
Thank you:
Mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grandam »</TD></TR><TR><TD CLASS="quote">Hello so I can use the 205-50-15 and there will be know problem what is the difference between the 205-50-25 and the 195-55-15 and also if I use the 205-50-15 will the car be higher off the ground compared to the 195-55-15.
Thank you:
Mark </TD></TR></TABLE>
Stock tire size is 185/65-14
That's 23.5" total diameter.
205/50-15 has a total diameter of 23.1"
and
195/55-15 has a total diameter of 23.4"
So as you can see, the difference is null. You're comparing 3 or 4 tenths of an inch.
If you were shooting for exactly the same size on a 15" rim 195/55-15 or 205/50-15 would be your best bet
Thank you:
and
Here is a web site that will tell you the over all and how many revs per mile and all the specs http://www.miata.net/garage/tirecalc.html
with how low my car sits i only have a slight rub issue when there's 4 people in the car when i turn very hard to the right but besides that no complaits and i personaly like the ride quilty better with 205s abit softer and more of a contact patch with road and car will sit a touch lower then stock but not even enough to notice, i just wanted the same diamater of tire or smaller for acclertion
panchlow
11
10-06-2010 08:57 PM
