Best tire size for eg on 2 inch drop?
i have 195 60 15 and the back tires rub on the top when im going up a driveway...
wondering if anybody has a better set up that doesnt do this?
could 195 50 15 be way better?
(idk if i should of put this post in the tire sec. but i thought sum one would reply here faster)
Re: Best tire size for eg on 2 inch drop?
The "correct" tire size would be 195/50 R15... The goal is to keep the same overall diameter as the stock wheel/tire setup... So more rim = less tire...
318 Curves, 11 miles
So it sounds like you're already running taller tires than stock, if you're running 60s. Your speedometer is probably off too because of that.
You should be running 50s. They're the stock tire size, and being shorter, will rub less. The 60s should have a total diameter of 19.61", while the 50s should have a total diameter of 18.84". Your tires are 0.77" taller than stock, and that's why they rub.
Wolfram Alpha is your friend: http://www53.wolframalpha.com/input/...95mm+%2B+15%22
yea i just got the blades couple days ago..
the previous owner had
185 60 15 in the front & 195 60 15 in the back.
time for new tires anyways...
What kind of tires do you guys recommend? i am a daily driver in so cal.. so no snow for me, only rain..
heres an picture of how to determine tire size while keeping near the same OUTSIDE DIAMETER
