Need Help with Timing Marks!!
Old 02-06-2006, 05:17 AM
trecool44's Avatar
Default Guide to confusing timing marks
I figured out how to read my timing pointer accuratly. For anyone else who is having trouble with their ignition timing pointers here is the answer. Take out your #1 spark plug. Put a long skinny screw driver down into the cylinder and rest it on top of the piston. Then with a socket on the crank bolt, rotate your motor until the screw driver has reached its highest point. This will make sure that your #1 cylinder is at TDC. Then look at the TDC groove ( the far top one) on the top of your crank pulley and see what is pointing to it. Because you know that your motor is at TDC, whatever is pointing at the TDC mark is the correct pointer spot to you use to measure the timing.
Modified by trecool44 at 5:26 AM 2/10/2006
Modified by trecool44 at 5:30 AM 2/10/2006
Old 02-06-2006, 07:23 AM
the soL that could's Avatar
think should be 2 "markings" you line up. just keep in mind a V, i don't know how to explain this ****.
Old 02-06-2006, 04:56 PM
trecool44's Avatar
Default Re: Need Help with Timing Marks!! (trecool44)
bump, sry for such a stupid question, but i need to get it right
Old 02-06-2006, 05:13 PM
movingIIshadow's Avatar
uh.... rectangle? The pointer works like a rifle sight, you line up the two pointers straight onto the middle of the three-in-a-row marks on the crank pulley. You have to look from up above straight down onto the pulley, looking through the sights that stick out of the plastic cam covers.
Old 02-06-2006, 05:17 PM
s13browe's Avatar
Default Re: Need Help with Timing Marks!! (movingIIshadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by movingIIshadow &raquo;</TD></TR><TR><TD CLASS="quote">uh.... rectangle? The pointer works like a rifle sight, you line up the two pointers straight onto the middle of the three-in-a-row marks on the crank pulley. You have to look from up above straight down onto the pulley, looking through the sights that stick out of the plastic cam covers.</TD></TR></TABLE>
yeah you have to lean over and eyeball it straight down like a rifle sight..
Old 02-08-2006, 12:52 PM
trecool44's Avatar
bump
Old 02-12-2006, 06:08 PM
Default Re: Guide to confusing timing marks (trecool44)
I thought the white one like a centimeter apart from the three colored ones was always the TDC mark.......
natebaur
05-17-2009 10:35 AM
civic89si666
12
12-21-2006 02:48 PM
JDMTurboCivic11
05-01-2005 08:32 PM
90crxmike
10
03-21-2005 09:52 AM
Creepin4DR
12-10-2004 07:57 PM
Quick Reply: Need Help with Timing Marks!!
