NEED HELP WITH SWAP
NEED HELP WITH SWAP
I am looking to buy a Del Sol and do a motor swap, I just need to know which motor i should throw in there. I want to figure all this out before i get the Del Sol so i can do it all at once. THANX
Re: NEED HELP WITH SWAP (O-Face)
lots of knowledgeable people here..but come on..you gotta give us more info...
whats your goal?
how much you got to spend?
do you want to do this yourself...as in, do you want the easiest bolt-in swap?
have you use SEARCH to find some info?
whats your goal?
Re: NEED HELP WITH SWAP (SD350z)
use search, lota info in archives, just remember yous gotsta have dohc delsol shifter linkage to use any b-series swap. teggie linkage will not work.
Re: NEED HELP WITH SWAP (dohcdelsol93)
Try searching and being more descriptive of what you're looking to do with your car. If you get the si(?) then I would just build the z6 and see if you like it. Most people rush into swaps just because everyone is doing it and you don't know any better. Work with what you got, then change.
CHINKA
04-06-2007 03:15 PM
