Vibration when accelerating
Old Jul 6, 2005 | 11:24 AM
DeeCeeTwo's Avatar
Default Vibration when accelerating
When i accelerate from 2500-4500 there is a strong vibration coming from the front. i changed my half shaft, axles, rotated my tires, got a new wheel bearing, and even put a new flywheel in. still vibrates. anyone know what it could be? motor mount(s)? thanks
Old Jul 6, 2005 | 11:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Try accelerating, and when it starts to vibrate, close the throttle and see if it still vibrates or not. If not, then it's still your axles, which I would not rule if you used rebuilt axles. I went through 4 sets of rebuilts before I finally got a set that didn't vibrate like hell.
Old Jul 6, 2005 | 12:29 PM
DeeCeeTwo's Avatar
yea...its only when giving gas, when i lay off its smooth, i got that warranty from autozone, and there axles are re-built. thanks pat
Old Jul 6, 2005 | 01:03 PM
Chris F's Avatar
Default Re: Vibration when accelerating (DeeCeeTwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeeCeeTwo &raquo;</TD></TR><TR><TD CLASS="quote">motor mount(s)? thanks</TD></TR></TABLE>
Does it shake the steering wheel much, or just the whole car?
Could be motor mounts too. You can see how much it moves if you put it in gear with the e-brake on, and the hood up, and let the clutch out without moving the car. If you use 5th gear you should be able to give it lots of gas/clutch and not overpower your e-brake, but still be able to see what all that torque does to your motor.
-Chris
Old Jul 6, 2005 | 02:03 PM
Integra_drk's Avatar
yes, i had the same problem, motor mounts and transmission mounts fixed it.
Old Jul 6, 2005 | 02:11 PM
DeeCeeTwo's Avatar
I'm gonna change my axle in a bit and see if that helps, if not then i'll do ur idea chris and see what happens. thanks
Old Jul 6, 2005 | 07:10 PM
Community Builder
Default Re: (DeeCeeTwo)
Okay yeah, you got those CCT-brand axles, and I guarantee that is the problem. I got mine from NAPA but they carry the same brand, and it took me 4 sets to finally get one that drove smoothly.
I also had to use a tape measure at the store each time I got another set to check their length, because the first set I got had the boots clamped down too far in on the axle shaft, making the free length of the axles too short, which would have over-extended the boots when I put them on the car.
Old Jul 6, 2005 | 08:30 PM
Spectrum24x's Avatar
Default Re: (PatrickGSR94)
I got a build on my motor, and afterwards my gas pedal has always vibrated at 7-8k rpm... any ideas about that? don't mean to jack the thread, but its similar.
Old Jul 6, 2005 | 09:40 PM
DeeCeeTwo's Avatar
k, i replaced my axle with a autozone one again just to see, it got smoother, but still vibrates a lil. i'm pretty sure it is my axle. i got polyuathene inserts in the rear, so it shouldnt be it i think? i think i'm gonna by some stage 1 axles from islandmotorsports for like 3 bills, or does anyone know another place for cheaper?hopefully that stops it. thanks again for the help everyone...
Old Jul 7, 2005 | 03:33 AM
Community Builder
Yeah I think new axles would be your best bet if you have the money, otherwise you might have to keep changing axles like I did, which is a total PITA.
ILOVEYOURHONDA
Sep 25, 2009 08:50 PM
Coltrane
Feb 22, 2005 08:22 PM
Turbocoupe97
Sep 5, 2004 11:26 PM
vtec11000
Aug 26, 2004 07:47 AM
All_Motor_Rex
Feb 3, 2004 02:17 PM
