need help with shift knob???
New User
need help with shift ****???
its a BLAZE shift **** heres a picture of it. but the problem is taking it off. when i got the car it was already on there. there are some minor scratches due to the stress it has cause me. i tried everything, there is no screws in the 4 holes with screws are sappose to belong. please help if anyone have any idea how to take this sucker off. sorry if picture is kind of blurr.
http://www.geocities.com/tys_lees200...?1013993470433
[Modified by hatch_react, 4:45 PM 2/17/2002]
New User
Re: need help with shift ****??? (hatch_react)
if you dont care about the shift **** then try using a hack saw on it, that would be your last option in my opinion.
i think its a nice ****..ive know and seen guys use strips of duck tape to fill in gap between the shift lever and inner cavity of the ****..then using super glue to tighten it..if they ve done this.. ?? the hacksaw idea might be ur only hope of getting it off...or replacing the shift lever...guess the previous owner never intend d to take it off again
New User
Re: need help with shift ****??? (deepnite)
well i like the short shifter that i have on. its just the ****. i cant really race with this sucker on. a lot of miss gear. any other suggestion.
last resort, remove the shifter fromt he tranny and put heat to it and tap around it to loosen any adhesive then try again..i can see this is a pain in the ***
Is their a little ring collar on the bottam of the ****? If so, spin the collar off and there should be 2 or 3 allen screws, remove those. If it is just the old twist style know, get some vice grips for leverage, although that will jack up the shift ****....if you can post a better pic of the shift know so we can see whats going on.Later!
New User
Re: need help with shift ****??? (iceburgslim)
there is nothing from the bottom that is holding it. theres about 4 holes where scres are sappose to be at, but there arent any screws. but on the top theres like a little cap where i can slightly move it little side by side. maybe a 1 cm movement or less. anyone think there might be something from the bottom of the shifter that is holding it? i doubt it though, its one of those that you twist off. im trying to hold my patients a little longer till this weekend, if i cant take that sucker off, im gonna grind it off with my grinder.
