Need help with OBD0 B16a into OBD1 VX HB !
I need some help everyone. I just bought a 1992 VX HB the other week for a good price. I also bought an OBD0 B16a. It the XSI "big vtec" version and came with everything but tranny. Its pretty clean and Im wanting to put it in soon. However, I dont have a tranny or mounts or ne-thing else. I have access to gettin an obd1 re-built gsr hydro. tranny, and a set of Hasport OBD0 to OBD1 mounts. Will this set up work for the swap? Also, what are someother things I will need to get in order to get this to work? Any info would help. Thanks.
Re: Need help with OBD0 B16a into OBD1 VX HB ! (1992vxhatch)
get that gsr or a itr or b16a trans. you will need a OBD1dist, I would use all 94-teg mounts. you will need to do some mods to the vx engine harness to make it work on that motor unless you get a 92-95 si/ex harness or 94-95 delsol dohc vtec one or 94-95 gsr one. you can use a dx or ls harness but will have to add wires for vtec and knock. also if this a OBD0 motor the tbody does not have the map on the top. some people swap whole mans to OBD1 style with the map on top of the tbody
mynameizstitch
01-26-2010 06:11 AM
