need help with engine swap in a 99 dx coup.
i have a 99 dx coup that still has the stock non vtec motor i it. my question is i am putting a ls swap in it and i need to know what to do about the mounts? i dont think i can swap it rite over cause the mounts dont look anything like any b-series i have ever seen. will i have to cut the mounts off the frame and weld in new ones? or would it be easier to just put a single cam vtec in it and boost it?
Re: need help with engine swap in a 99 dx coup. (killerB16A)
what year ls are u swapping in. you can us stock si mounts or buy swap mounts, but you also need the si t bracket for the back mount and the si driver mount bracket that bolts to the block. And you will have to do a iac fix, but thats gotta be done either way you go, single cam vtec or b series.
Re: need help with engine swap in a 99 dx coup. (abusedhusband)
aic? and its the frame side bracket im worried about. it doesnt look anything like any honda mount i have seen??? i will see if i can get a pic
Re: (killerB16A)
yeah youll have to swap the drivers side upper mount, and also use the 99 si t mount in the rear.
also the earlier poster was talking about the iac valve which he is talkign about changing 2 wire to 3 wire hook ups ..... searching is your friend
Re: (bleedblue94)
i know to search but if someone says something to me in my post i will ask what it is. thanx for the info i appreciate the help!!!
Re: (killerB16A)
wasnt trying to be an *** ... just saying that im sure youll find all youre answers. regardless are you just piecing this all together or did you buy a full swap?
Re: (bleedblue94)
well my friend has a single cam turbo set up and a ls swap he said he would sell me one of them im just trying to find the easies rout. if i get the single cam vtec turbo set up i will be replacing the pistons and rods and getting the head rebuilt. im thinking i want the single cam. i just searched for the iac valve and i cant find anything on going from 2 to 3 wire?
