what mounts to use for swap
I was wondering what mounts i need to swap a ls block in my 99 hatch? Is it just the rear "T" si mount that i need and i can reuse my other d mounts? please someone lmk.
Re: what mounts to use for swap (Ari Gold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ari Gold »</TD></TR><TR><TD CLASS="quote">if in a 99 hatch use 99 si mounts and brackets</TD></TR></TABLE>
That is not correct the 99 si will be mounts for the B16. You can use all the mounts except for the upper drivers side. The B18B mount is different on that side so you will have to find an Integra mount for that side. Just get the mounts from an LS Integra they will all bolt right in without trouble, that will be a better route for you I think.
Re: what mounts to use for swap (ralphie14)
well i just got the 99-00 si rear T mount bracket. thats all i need tho right? someone was telling me that i can reuse the other mounts. anyways lmk+
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralphie14 »</TD></TR><TR><TD CLASS="quote">
That is not correct the 99 si will be mounts for the B16. You can use all the mounts except for the upper drivers side. The B18B mount is different on that side so you will have to find an Integra mount for that side. Just get the mounts from an LS Integra they will all bolt right in without trouble, that will be a better route for you I think.</TD></TR></TABLE>
u can used any B seires mounts except for the upper driver side .
jaydm ferio
10-26-2004 08:06 PM
