NEED HELP! Dizzy problems/not starting
Old 02-17-2006, 11:45 AM
xkagax's Avatar
Default NEED HELP! Dizzy problems/not starting ****update*
Ok here's the simple version: so I changed my dizzy with another. Wouldn't start, so put the one on that I took off (was working fine yesterday) still won't start... what the hell how is the possible? Someone please help I need my car to run, and uhm.. its not? someone said turn the part of the dizzy that connect to the cam around 180 degrees, but it won't go on that way so that's no help...
****EDIT 2/22*****
Ok new starter didn't do ****. So we determined I'm getting great spark, and fuel. When you crank it and hold the gas the motor def. breathes and you can her it like very lightly coughing kinda, but no start. Any more ideas?
Modified by xkagax at 9:35 PM 2/21/2006
Old 02-17-2006, 11:55 AM
I3ooS710's Avatar
Default Re: NEED HELP! Dizzy problems/not starting (xkagax)
Sounds like it's your ignitor. . .
But before we jump to that, what are the symptoms? Is your car turning over? Are you getting spark? Is you fuel pump working? Possibly your main relay has gone bad.
Old 02-17-2006, 01:32 PM
b16hatche's Avatar
my car is doing the exact same thing. i replaced my distributor 2 months ago and it just went out(AGAIN). so i pulled it off figured out i couldnt get it tested so i put it back on and it ran perfect. now that its parked in my garage it wont start again? this just a bunch of bad luck?
Old 02-17-2006, 03:20 PM
xkagax's Avatar
Default Re: NEED HELP! Dizzy problems/not starting (I3ooS710)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ooS710 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like it's your ignitor. . .
But before we jump to that, what are the symptoms? Is your car turning over? Are you getting spark? Is you fuel pump working? Possibly your main relay has gone bad. </TD></TR></TABLE>
it like turns over once, then just makes some weird like grinding sound like its trying to start but won't. How do I test for spark? And no main relay is fine I tried my friends. I dunno it doesn't seem like it'd be the dizzy, I have two and neither one will work...
Old 02-17-2006, 07:53 PM
Brick Top's Avatar
the grinding sounds like your starter.
Old 02-17-2006, 09:31 PM
InJ3cted's Avatar
Default Re: (brick top)
Make sure your not 180 off take out your dizzy turn the end of the dizzy and put it in
Old 02-18-2006, 06:57 AM
xkagax's Avatar
Default Re: (InJ3cted)
when I try that the dizzy won't go in?
Old 02-18-2006, 10:47 AM
xkagax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">the grinding sounds like your starter.</TD></TR></TABLE>
well now its not grinding or making any noise at all.. so I took out the starter and had it tested at autozone.. nothing. A new one gets here on Monday so I hope this fixes it.
Old 02-18-2006, 10:50 AM
Sliced Beard's Avatar
Default Re: (xkagax)
first of all, did you bother to check your battery?
Old 02-18-2006, 01:44 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkagax &raquo;</TD></TR><TR><TD CLASS="quote">
well now its not grinding or making any noise at all.. so I took out the starter and had it tested at autozone.. nothing. A new one gets here on Monday so I hope this fixes it.</TD></TR></TABLE>
nothing wrong with it?
or its producing nothing?
Old 02-18-2006, 07:51 PM
xkagax's Avatar
it's producing nothing.
Old 02-18-2006, 10:10 PM
Brick Top's Avatar
ok, let us know if that solves it.
Old 02-21-2006, 11:01 AM
xkagax's Avatar
Ok I got a new starter, still nothing. I'm getting spark and getting fuel.. so its the dizzy I guess??? I'm gonna work on taking the guts out of my stock d16y7 dizzy and puttin them in my GSR dizzy.. will that work?
Old 02-22-2006, 05:47 AM
xkagax's Avatar
Default Re: NEED HELP! Dizzy problems/not starting ****update* (xkagax)
bump for update
rodriguez
05-26-2008 10:59 PM
xkagax
02-22-2006 05:36 AM
knightnam
10-13-2005 04:33 AM
FourthGenHatch
03-11-2003 11:40 AM
Quick Reply: NEED HELP! Dizzy problems/not starting
