need help with brake lines
ok i searched and i couldnt find a write up or any good pics showing how to change ur brake lines on a 92 cx hb.
so far i kno that the bolt connected to the calipers i took it off brake fluid came out and i made sure that the brake fluid stayed past the low point mark so i wouldnt bleed them but iam having problems taking of the top part of the brake lines on the front of the car..... someone told me to use plyers but what the hell do i put them on i cant see a bolt. so how does it come off? plzzzz help trying to do this before the motor swap 2night so i wanna get them knocked out thanks
Re: need help with brake lines (tracebuzta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tracebuzta »</TD></TR><TR><TD CLASS="quote">use plyers to pull out the clip and then use a flare wrench on the bolt on the line</TD></TR></TABLE>
actually your gona want to loosen flare nut first then take out the clip other wise its gona be all loose and hard to do. and your going to have to bleed the brakes regardless. just follow the rubber line youll see it.
Re: need help with brake lines (e jay one)
ok i see the thing where is the clip? is it the braket that is holding the line? how do i remove that or do i remove the brake line from that ? iam lost
Re: need help with brake lines (mark_is_gay)
the bracket the holds the line has the clip on it. the hard line stays attached to the bracket and your going to disconnect the soft line from the hardline. the clip may need some prying and pulling but it will come off
dgdarien
09-15-2009 04:23 PM
DOHCgarage919
10-08-2007 04:38 PM
