Need advice on replacing front rotors
Need help on replacing front rotors
I'm trying to replace the front rotors myself instead of bringing it to the dealer cuz they want an arm and a leg for it. For that price I can buy my own tools and jack and everything I need to do it myself.
The problem is that after i removed the wheel, the front brake pads and removed the lower caliper bolt and moved the caliper aside, followed the Haynes manual best I could, but the two caliper mounting bolts on the backside are frozen.
I tried wrench with a hammer, the impact driver with the socket on it, even biting it;. (didn't taste too good) How can I get those two bolts off without having to drill them out (cuz that doesn't seem like a good idea) ?
And while I'm at it, are there any other problems I should look at?
TIA.
TIA.
do not drill them off....
get some pb blaster or liquid wrench...or anything that eats through rust.
while youre at it, buy a section of pipe around 2-3' long. It will give you added leverage when you slide it over the ratchet/wrench.
