My EG won't start has fuel but no Spark!!!!!
Okay I went to the store and the car ran fine. No problems. Then I get out put the alarm on and go about my buisness. Get back to the car and now the car won't start. What the hell. So I check the alarm and it's fine. Check all fuses and all fine. Changed to new distributor and still no spark. The pump does prime but I checked the plugs last night to see if I had spark and nothing. I went through all the checks that I normally go through. But still get nothing. I also checked the ECU with another. And still nothing. Also checked the Main relay with a spare that I have. NOTHING!!! Just getting no spark. I need help bad. The car has a 1995 GS-R swap. It has everything connected because it is Bar'd. And the motor is stock. Help PLEASE!!!!
Re: My EG won't start has fuel but no Spark!!!!!
something happened to me like that but in my case i have a auto to manual conversion so i have the automatic shifter harness still attached and if its not in park the motor wont turn at all .. it serves as a good kill switch along with others i have
check that the wires that are inside the connectors are actually connecting to the other wires. i was throwing a TDC cel that put my car down for a wk bc i had one single wire inside the connecter not completely connected inside the dizzy harness clips. it was pulled out just the slightest bit.
With the key in ON(II), do you measure battery voltage on the Blk/Yel wire attached to the coil and igniter unit in the distributor?
dope93si
08-23-2004 08:52 AM
