my d16y7 bottom block have a hole and i was wondering?
i was wondering could i use a d15 or even a d16 bottom block but use the same head and component,intake manny dizzy ,etc will my car run right with this set up thanks in advance
Re: (naRIPSTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naRIPSTA »</TD></TR><TR><TD CLASS="quote">Sure you can, as long as it's a D series block..single cam D though.</TD></TR></TABLE>it wont be a problem?ask in gas mileage?idel funny?dont run normal?
318 Curves, 11 miles
Re: (skateboard c)
Shouldn't have any problems assuming you get a good block and your head is good.
If I'm wrong, someone can correct me on this:
I don't know if OBD level matters on D series blocks... it may make it easier if you stick with the same OBD level as your car - if it's OBDI, get an OBDI block. If you have an OBD2 car, the ECU may be looking for sensors that don't exist on an OBDI block.
Re: (Vindicator9000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vindicator9000 »</TD></TR><TR><TD CLASS="quote">Shouldn't have any problems assuming you get a good block and your head is good.
I don't know if OBD level matters on D series blocks... it may make it easier if you stick with the same OBD level as your car - if it's OBDI, get an OBDI block. If you have an OBD2 car, the ECU may be looking for sensors that don't exist on an OBDI block. </TD></TR></TABLE>
yes, that's correct the OBD2 motors all have a CFK sensor on the lower timing pulley (crank pulley) for the timing belt... but you can bypass this with a wiring trick if necessary to use an older block. And also I think OBD2 D-series are the only ones with a knock sensor too...
Re: (IndySporty)
^^^^That's what I thought.
Although if he's really in California (I didn't notice before), he probably wants a same year or newer engine to keep it legal.
JDMBrosDude
19
08-29-2007 08:37 AM
