my 97 dx has overheating problems please help
one day i was driving my car and i notice the temperature just started rising to the h on the gauge. i thought it might of been my hoses so i changed my upper radiator hose. i ended up having the same problem plus i also know my fan wasn't turning on. i cant drive a block around my house without it over heating and steaming under the hood. any suggestions ?
Re: my 97 dx has overheating problems please help
1. check head gasket
2. check radiator cap see if it no good
3. check radiator to see it bad, sometimes it clogs up**
4. check thermostat
5. check fan switch** located on thermostat housing area
6: if running full water please add coolant**
4. check thermostat
found out that i need a new thermostat where my lower radiator hose is and my fan is working did the jump my fan motor went thanks for the help guys
