mouting teg rear sway on my 94 coupe..help!
i know some of you guys have this set up...i have the rear LCA's and sway bar with endlinks for my 94 coupe....i used to own a 00 si which had the mouting holes for the bolts....but this car doesnt...is there a kit or something i can use to mounting the rear sway bar onto the subframe?.... pics of this installed or the installation will be appreciated....need ideas the thing is just sitting there..
Re: mouting teg rear sway on my 94 coupe..help! (eg6beater)
My 94 ej had the holes for the mounts but there was not a nut welded to the inside of the frame. The holes were covered over w/ body undercoat and dirt. I,m not shure the mounts from a teg are the same though. The lca,s will work 'cause thats what I'm using but I'm using the mounts and bar from a 92 4-door.
00eddie00(95eg)
Northern California (Sales)
01-01-2012 05:03 PM
JDM_dreamer
01-08-2007 08:17 PM
