motor swap help
motor swap help
blew my y8 in my ek hatch
swap it with a z6 used my obd2a wire harness
INtakeManifold: stock y8
Header:stock
Motor:d16z6
tranny :stock y8
i convtered tha dizzy to obd2 and plug everything in and cranks but wont turn over
help
tha z6 has been sitting for a month outside?????
Header:stock
Motor:d16z6
tranny :stock y8
help
Sol to Sol
Re: motor swap help (garagetunedInc)
Um, cranks IS turning over... I take it you mean it wont fire?
Check the fuses, maybe?
Then go down the tree, Spark, fuel, timing, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garagetunedInc »</TD></TR><TR><TD CLASS="quote">it had a obd0 dizzy b4 tha guy niger rig it???</TD></TR></TABLE>
Wow. This is the first time i've seen this. Noob, id suggest you use better word choices in the future, and not use the phrase "[racial pejorative] rig" because that is quite offensive. This is a tech site and really has no place for slangs like that. Easily the most offensive thing ive seen on HT man. Try to control your "Southern Pride" until you are OFF Hona-Tech, sitting around drinking with your monster truck buddies
THe obd0 dizzy if anything would've just had changes it the pervious wire harness. If you used yours it should be fine, however the z6 didnt come with a knock sensor so you'll want to find a way around that. My guess is your timing is probably off.
tha car runs good it was tha dizzy that was bad
but now wen i tired to go it wont i have clutch pressure and in goes in gear it just rev's up and tha mph goes up to???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garagetunedInc »</TD></TR><TR><TD CLASS="quote">tha car runs good it was tha dizzy that was bad
but now wen i tired to go it wont i have clutch pressure and in goes in gear it just rev's up and tha mph goes up to???</TD></TR></TABLE>
sounds like the axles arent popped in all the way also quick ???? you say that you are using a d16z6 in an obd2 car what did you do about the crank angle switch that is bolted on the oil pump on your old motor the d16z6 dosent have one
Re: (MilanoRedCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRedCoupe »</TD></TR><TR><TD CLASS="quote"> OBD 1 motor in an OBD2 car.
i don't know about that since it can be done.
try with an obd1 engine harness and maybe a conversion harness to the right ecu
what ecu are you running btw?
you sir deserve to be kicked in the *****.
good luck with your car
Its the same motor -2 sensors
Re: (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK »</TD></TR><TR><TD CLASS="quote">
Its the same motor -2 sensors </TD></TR></TABLE>
My point was why bother with that, when you can pick up a y8 for the same money and it is a newer engine designed to go in that generation of civic.
this dude says [racial pejorative] rig
but my posts get deleted for far less?
do i take this as honda tech supporting this sort of language????? HMMMMMMMMM
so next time i pick a racial slur i should stick to the blacks ehhhh...GOTCHA
PardonmyEK9
60
03-23-2011 05:04 PM
91integraLSVTEC
09-14-2007 01:02 PM
