Motor Mounts... Will this still work?
I already posted this in "Hybird" forum but no one has responded.
I am about to pick up some Stock GSR Motor mounts for my sawp. The guy I am buying them off of has told me that the mount on the driver side, closest to the headlight has a little problem. The rubber that is inside the mount is crack.
Is this a big problem? Will it work? Does it need to be fixed? Help
Re: Motor Mounts... Will this still work? (JDM CTR EK)
well the mount new is $40-50 new but i would just get a engine mount insert and it should fix that problem.
Also....your gonna have to use ur stock upper driver side mount bcuz the GSR has a differnt one
you will need the gsr mounts on the fronts like where the a/c bracket,tranny bracket. You'll need 99-00 si rear bracket and you can use your top tranny and driverside motor mount. hit me up if you got any probs
Re: Motor Mounts... Will this still work? (wm5holla)
Ok another thing. The rubber that is inside on of the Mounts (rear) is cracked. If i buy new inserts will that replace that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla »</TD></TR><TR><TD CLASS="quote">where can u buy motor munts inserts?</TD></TR></TABLE>
Someone told me to go here. http://www.7453217467431.com/p...39976
