motor mount kit?
Old 07-06-2003, 08:22 PM
LSturboEX's Avatar
Default motor mount kit?
do u need a moor mount kit to swap a b16 in a 92-95 ex coupe?
Old 07-06-2003, 08:52 PM
hardcorepreston's Avatar
no use integra mounts and up at the top theres a search button
are you goin to do this swap?
Old 07-06-2003, 11:58 PM
built562's Avatar
Default Re: (hardcorepreston)
or you can use the b16 mounts from a jdm civic that cam with the b16 or del sol vtec mounts
Old 07-07-2003, 02:51 AM
GZR4DR's Avatar
Default Re: (akumaracer)
Second gen B16's bolt right in if you use the mounts that came with the motor.
Old 07-07-2003, 11:48 AM
LSturboEX's Avatar
yes, i am planning on swapping a b16. not sure on everything i need and dont need. i was told i already have the right wiring and my ex ecu will work too. wasnt sure on the motor mounts though.
Old 07-07-2003, 12:10 PM
tek_civic's Avatar
Default Re: (LSturboEX)
you need to change the ecu over, you will not be able to rev that high and it won't be getting all the fuel it needs.
Old 07-07-2003, 08:57 PM
LSturboEX's Avatar
Default Re: (tek_civic)
also, i was wondering if it would be worth it to swap a cable clutch to my car since it has hydraulic right now? almost all the b16's that i have found for sale are obd0 and cable clutch, will this work in my car? (95 ex coupe) thanks for the help
Old 07-07-2003, 09:00 PM
Dancing is Forbidden's Avatar
you have to have the conversion kit from hasport. You can do it, just takes a little bit more time and effort. oh and you CAN run that evcu just get it chipped. A LOT of people do this with nice outcomes. A chipped P28 is very niiiiiice.
Old 07-07-2003, 09:37 PM
New User
Newman's Avatar
You can also use the HCP hydro-cable conversion kit. This particular one has been on the same 94 EX coupe with B18B and YS1 GSR cable tranny for over 2 years now.... never once had a "dead pedal" feel and has been taken tor the track a few times and launched on hard.... still perfect feeling to this day.
CRX30436
03-17-2008 03:23 PM
teamkawy55
11-08-2004 04:22 PM
typesguy
01-29-2004 06:53 AM
sohcvtec1995
09-22-2003 10:44 PM
cademan
04-09-2003 07:42 PM
Quick Reply: motor mount kit?
