Mitsuba Main Relay (RZ 0132)
Old 08-16-2012, 08:43 AM
Steeve_Civic's Avatar
Default Mitsuba Main Relay (RZ 0132)
Hello,
I have some problems with this relay.
Sometimes it doesn't work.
Do you have a good deal to buy a brand new one?
Is there a possibility to get out it and connect it in direct?
Old 08-16-2012, 08:48 AM
Former User's Avatar
Default Re: Mitsuba Main Relay (RZ 0132)
http://techauto.awardspace.com/mainrelay.html
Axatax's Avatar
Try opening the case and re-flowing the solder.
Old 08-16-2012, 09:05 AM
thank you for the link.
Just opened it, and going to do instructions
Old 08-16-2012, 11:21 AM
Resident Gearhead
BryanM.'s Avatar
Such an easy fix too. I get theses for cheap at the salvage yard, I re-solder them and give them to my friends.
http://www.flickr.com/photos/mcvtec/7797095864/http://www.flickr.com/photos/mcvtec/7797095864/http://www.flickr.com/photos/mcvtec/7797095578/http://www.flickr.com/photos/mcvtec/7797095578/
Re-soldered joint
http://www.flickr.com/photos/mcvtec/7797095408/http://www.flickr.com/photos/mcvtec/7797095408/
Old 08-16-2012, 11:23 AM
LogicMotorsports.com's Avatar
Good choice. Its an easy fix
Old 08-16-2012, 01:15 PM
Bradshaw's Avatar
need to do this. really tired of my car randomly not starting. usually if i turn it off and turn it on quickly afterwards it will fail. just wait 5 min and then it starts right up.
Old 08-16-2012, 01:39 PM
Also check the ignition switch.
Old 08-16-2012, 02:05 PM
fragmare's Avatar
Yea, I had the same thing going on a while back. Just get a soldering gun and some rosin core (not acid core) solder and resolder the cracked joint(s). If you really want to do it right, get a desoldering tool and suck all the old solder off every joint and resolder each joint from scratch. It'll essentially be like new.
xXSilentScreamXx
44
08-05-2007 07:53 PM
bobdlee84
08-19-2006 11:23 AM
GSRinmyCRX
06-14-2006 05:28 PM
Quick Reply: Mitsuba Main Relay (RZ 0132)
