Mini me swap with a y8 automatic head?
Does it make a difference if the Y8 I plan on putting on my Y7 is automatic or manual? I know I need a manual ECU. But will the Head, intake and throttle body of of a automatic Y8 work or no?
Thanks!
Thanks!
Re: Mini me swap with a y8 automatic head? (Chaps1)
You need a manual intake manifold and throttle body, the head doesn't matter. You also need to do the 3 wire to 2 wire IACV conversion. Go to ff-squad.com and find the write-up.
Re: Mini me swap with a y8 automatic head? (sicones)
can you explain why the intake and manifold won't work. Also I searched ff squad and can't find the write up.
Thanks for your help!
Seagull Management
The manual Y8 uses a different throttle body and intake manifold than the automatic, The automatic has the IACV on the throttle body while the manual has the IACV on the back of the intake manifold.
Thanks for all your help guys. I found a great write up on doing the mini me. But I had a question about what ARP head studs to order? I'm not sure where / what combo to get.
11-04-2012 07:24 PM
SOHC_Brian
01-15-2004 08:57 AM
