Mini Me Swap!!
Old 05-20-2005, 02:41 PM
B A N N E D
97civicsedan's Avatar
Default Mini Me Swap!!
What Mini Me Swap can i do on my 1997 Honda Civic LX Sedan 1.6L D16Y7. Is it possible to put a vtec head from a del sol????
Old 05-20-2005, 02:45 PM
rubber's Avatar
Default Re: Mini Me Swap!! (97civicsedan)
you can, you just have to do all the normal mods. head, manifold, computer etc....
fastfu's Avatar
http://www.jdmuniverse.com/for...pp=15
next time try doing a search
Old 05-20-2005, 02:47 PM
B A N N E D
Can I just have the vtec head only with the same block and just wire the vtec into the oem computer?????
Old 05-20-2005, 02:49 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicsedan &raquo;</TD></TR><TR><TD CLASS="quote">Can I just have the vtec head only with the same block and just wire the vtec into the oem computer?????</TD></TR></TABLE>
YOu can't wire the vtec to your oem computer because it doesn't know about vtec. There's a lot more to the head swap than just putting the head on.
Old 05-20-2005, 02:50 PM
B A N N E D
Default Re: Mini Me Swap!! (chowmien)
So what else do i change to get the head to work???
Old 05-20-2005, 02:51 PM
EK k kay's Avatar
Search
Old 05-20-2005, 06:32 PM
KtHaNxBai's Avatar
dont forget about gettin the flux capacitor,
it gives u 20 extra hp.
Old 05-20-2005, 07:44 PM
neutron91's Avatar
you can use a vtec controller to engage the vtec... thats a cheap way out but it works
Old 05-20-2005, 07:54 PM
EK k kay's Avatar
Default Re: Mini Me Swap!! (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">you can use a vtec controller to engage the vtec... thats a cheap way out but it works</TD></TR></TABLE>
Buying the ecu is cheaper than buying a VTEC controller. And if you use the y7 ecu your car will run lean and the air/fuel maps will be all messed up. And you can't use a VTEC controller to enable VTEC. You need an RPM switch to do that or use a switch connected to the solenoid to give it power when you need it, but those ways suck and do not do it.
Old 05-20-2005, 07:59 PM
neutron91's Avatar
not trying to argue here but ive seen it done on an accord... if he had an rpm switch im unaware of... all i know is he had a vafc and the stock ecu... he swapped on the vtec head and it worked... i know the ecu itself is cheaper in price... i meant the quality of the work is cheap... should have rephrased that
Jhauoli
Honda Civic (2001 - 2005)
03-17-2018 05:58 AM
hello_kitty5
01-12-2013 06:49 PM
civeocko95
01-05-2009 04:39 PM
Prorican
06-05-2006 08:06 PM
birdxa
01-10-2005 08:31 PM
Quick Reply: Mini Me Swap!!
