Mini Me Swap!!
Re: Mini Me Swap!! (97civicsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicsedan »</TD></TR><TR><TD CLASS="quote">Can I just have the vtec head only with the same block and just wire the vtec into the oem computer?????</TD></TR></TABLE>
YOu can't wire the vtec to your oem computer because it doesn't know about vtec. There's a lot more to the head swap than just putting the head on.
Re: Mini Me Swap!! (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 »</TD></TR><TR><TD CLASS="quote">you can use a vtec controller to engage the vtec... thats a cheap way out but it works</TD></TR></TABLE>
Buying the ecu is cheaper than buying a VTEC controller. And if you use the y7 ecu your car will run lean and the air/fuel maps will be all messed up. And you can't use a VTEC controller to enable VTEC. You need an RPM switch to do that or use a switch connected to the solenoid to give it power when you need it, but those ways suck and do not do it.
Re: Mini Me Swap!! (chowmien)
not trying to argue here but ive seen it done on an accord... if he had an rpm switch im unaware of... all i know is he had a vafc and the stock ecu... he swapped on the vtec head and it worked... i know the ecu itself is cheaper in price... i meant the quality of the work is cheap... should have rephrased that
