mini me starts, but wont stay running without gas
Old 11-09-2009, 11:15 PM
  #26
j0keefe21's Avatar
Default Re: mini me starts, but wont stay running without gas
i vote vaccume leak. sounds to me the only think possible if he just took off one head and popped in another. ( i hope you pulled the oil plug). either that or your timing really is off.
Old 11-09-2009, 11:59 PM
  #27
accord2civic2prelude's Avatar
flat side of dizzy? confused. I looked at the rywire.com pic and went off of that. Could that be wrong?
http://rywire.com/store/faqdesk_info...e3182df2734ff2
By the flat side, you mean where #3 or #4 are in the pic?
Old 11-10-2009, 12:00 AM
  #28
but with a vacuum leak, wouldn't the car still run, but really wierd? Even with a vacuum leak, it would shut off with out gas right? And yes, i pulled the oil plug on the block.
Old 11-10-2009, 05:24 AM
  #29
Jimster480's Avatar
yes it would run without a vacuum leak. no it wouldnt turn off without gas. It would idle high.
Old 11-10-2009, 03:30 PM
  #30
daymkimchee's Avatar
i appologize i ment the round side but yea rywire has it correct.Somtimes just because you see spark dosent mean its strong enough maybe try your ignition coil or another dizzy if you have one.I did have a customer at work who has msd installed and his car wouldnt start .When i put a spark plug to the wires it was getting spark but was looking kinda weak came to find out he had a dent in his msd coil which caused it to not work right replaced it and ran fine
red_crx_89
15
08-29-2009 10:05 AM
97civic07gsxr
19
02-24-2009 05:20 PM
Jos3ph
11-13-2008 04:35 PM
Circuit8
11-26-2001 03:14 PM
Quick Reply: mini me starts, but wont stay running without gas
