Mini-Me???
Mini-Me???
Alright so I'm planing on doing a mini-me vtec head swap. I'm putting on a d16z6 vtec head on my stock d15b7, and I was just wondering how much of a performance change I should be expecting from that. And also what kinds of gains should I be seeing by also adding a greddy 4-2-1 vtec header w/a high flow cat. Thanks for the info.
Re: Mini-Me??? (Dav94Lx)
Go here and type in mini me
https://honda-tech.com/zerosearch
try here too
https://honda-tech.com/zerothread/642479
try here too
Re: Mini-Me??? (95vxtealhatch)
You will gain a little power (emphasis on "little"). The header and cat will help a little bit.
In my opinion, mini-me's aren't worth the money. You're better off with an a6 cam swap.
If it's done correctly, you might net a 10whp peak gain. That's just a guess; I've never seen any dyno comparisons of b7/z6 mini-me's.
You might gain an additional 4-5whp from the header and cat (which is also a guess).
If you screw up your timing when performing the head swap, you might even lose power.
midorigreenmobi
22
03-20-2014 04:57 PM
