Mine Cam Gear is off 1 teeth, is it bad??
I change mine Camshaft yesterday, and it's running kinda weird, so i use the timming light to check mine timming and found out the Cam Gear is one teeth off, I'll it fix tomorow, but i want to know can it make any damgage to mine engine? btw i have a JDM B16A II
Re: Mine Cam Gear is off 1 teeth, is it bad?? (blackANESE)
mine car run pretty funny now specially around 2 and 3 rpm, it's doesn't go smooth, dam can't wait to fix it,
New User
Re: Mine Cam Gear is off 1 teeth, is it bad?? (power_civic)
I am not too familiar with your engine (or Honda's for that matter) but I was wondering which cam is off? Intake or exhaust? Is it retarded or advanced a tooth? And how many degrees is a tooth for your cam gears?
A tooth won't hurt your valvetrain (as in, no engine damage) but yeah it won't run as well.
Re: Mine Cam Gear is off 1 teeth, is it bad?? (TypeIII)
it will slip another
then you could be in serious trouble.
you need to fix it asap.
It didn't slip... he changed his cams and he screwed up when he put it back together.
pureplayaz
21
11-16-2008 02:11 PM
alterdcreations
01-24-2007 11:45 AM
