measure voltage
measure voltage
i want to test if my TPS is worn out, however i do not know how to put the multimeter's pole to get a reading, it seems that the back of the TPS connection has water prove connections?
Honda-Tech Platinum Member
Re: measure voltage (EkFG)
poke?
try backprobing. probe into where the wire go into the back of the harness. should be .45 volts with the throttle plate closed and around 5 volts at WOT.
