maybe you guys can help, im misfiring
Re: maybe you guys can help, im misfiring (Civiclx)
hrmmm...
is there any way the actual wire to that plug is messed up?
sounds like an unusual problem
bump
Guys help him out
bump
Guys help him out
What type of injectors are you running and how are they wired? If its only cyl 2 after it got messed up thats probably it. If you can go to a junk yard get a new connector i would rewire it up and see if that helps, just a thought.
I really still think that it's got to be an electrical problem somewhere between the dizzy and the sparkplug or something to do with a bad connection between the ECM and the injector if it's just happening in cylinder 2 mostly.
Re: maybe you guys can help, im misfiring (Ricey McRicerton)
hopefully my new wiring harness and ecu that is coming in soon should solve this problem, ill keep all of you updated!
thehulkLX
06-11-2016 11:30 AM
