temp guage Problems
Old Oct 22, 2002 | 02:27 PM
trutuner's Avatar
Default temp guage Problems
Ok heres what happened about 2 months ago i put a sender unit in, and my temp guage woked without any problems then for the past week it hasn't been working again any clue what the problem could be, is it shorting out, getting tripped by something??? please help!!!!!
Old Oct 23, 2002 | 12:23 PM
trutuner's Avatar
Default Re: temp guage Problems (trutuner)
any help?????
Old Oct 26, 2002 | 05:43 AM
trutuner's Avatar
no one's got any ideas???????!!!!!!
Old Oct 26, 2002 | 04:06 PM
trutuner's Avatar
up we go!!!!
Old Oct 27, 2002 | 07:13 AM
trutuner's Avatar
Come on guys please help me!!!!!!
Old Oct 27, 2002 | 05:42 PM
ken's Avatar
ken
Its a problem with the flux capacitor.
Old Oct 27, 2002 | 06:27 PM
trutuner's Avatar
Default Re: temp guage Problems (ken)
could there be any other problems or ideas!!!
Old Nov 11, 2002 | 08:24 AM
trutuner's Avatar
um we go again, please help me out someone???
Old Nov 25, 2002 | 01:48 PM
trutuner's Avatar
does anyone have any ideas????? please i need help here...
Old Nov 25, 2002 | 02:09 PM
Buckshot's Avatar
haha i cant believe after 2months no one has helped you
Old Nov 25, 2002 | 02:30 PM
94TealGSR's Avatar
Free bump.
Old Nov 26, 2002 | 12:18 AM
trutuner's Avatar
Default Re: temp guage Problems (94TealGSR)
yah tell me about it....please help!!!
Old Dec 1, 2002 | 04:52 PM
trutuner's Avatar
up we go again....
Old Dec 1, 2002 | 04:56 PM
NeoGSR's Avatar
i'd check the wiring, bad wire grounding out or something, or replace the sensor
Old Dec 2, 2002 | 04:23 PM
trutuner's Avatar
Default Re: temp guage Problems (killerlime)
any other ideas????...ttt
Old Dec 2, 2002 | 05:06 PM
94TealGSR's Avatar
Sounds broke to me.
Free bump again.
Old Dec 2, 2002 | 06:11 PM
jclau00's Avatar
hey i was gonna scan you a pic from my 98 integra helms but my computer with the scanner hooked up is conveniently broken right now. so here goes:
gauge test:
1. check the no. 25 (7.5A) fuse in the under-dash fuse/relay box before testing.
2. make sure the ignition switch is OFF, then disconnect the YEL/GRN wire from the ECT gauge sending unit and ground it with a jumper wire.
3. turn the ignition switch ON. check that the pointer of the ECT gauge starts moving toward the H mark.
CAUTION: turn the ignition switch OFF before the pointer reaches the H on the gauge dial. failure to do so may damage the gauge.
*if the pointer of the gauge does not move at all, check for an open in the YEL or YEL/GRN wire. if the wires are OK, replace the ECT gauge.
*if the ECT gauge works, test the ECT sending unit.
ECT sending unit test:
1. disconnect the YEL/GRN wire from the ECT sending unit.
2. with the engine cold, use an ohmeter to measure resistance between the positive terminal and the engine (ground).
3. check the temperature of the coolant.
4. run the engine and measure change in resistance with the engine at operating temperature (the radiator fan comes on).
*if temp = 133, then resistance =137
*if temp = 185-212, then resistance = 46-30
5. if the obtained readings are substantially different from the specifications above, replace the ECT sending unit.
--------remember, this is taken from a 98 manual. dunno if 94 is any different. hope this helps.
Old Dec 2, 2002 | 06:36 PM
trutuner's Avatar
Default Re: temp guage Problems (jclau00)
thank you i will try that, thanks for all the help guys, i really apreciate this!!!
MopdiT
Feb 19, 2008 08:51 AM
JunkyardDog
Nov 28, 2005 11:02 AM
LowAcura
Dec 30, 2004 12:12 PM
Civiclx
11
Sep 8, 2004 06:55 AM
fourdoorsleeper
Jan 23, 2004 02:59 PM
