Replacing map wire in ecu harness
Old Sep 2, 2003 | 04:52 PM
SOFLSOL's Avatar
Default Replacing map wire in ecu harness
Trying to strip my map wire to rewire my afc and while stripping the whole map wire came out of the ecu harness. I looked inside the square-ish hole and noticed a silver square type connector. Are those removable? How can I replace this wire? bad luck
Old Sep 2, 2003 | 05:17 PM
JayDM Honda's Avatar
Default Re: Replacing map wire in ecu harness (SOFLSOL)
you most likely wont need to replace the wire to your map sensor. the "silver square type connector" your talking about is removable. they make a special tool for removing this connector but a pick works just fine. Insert a pick into the map connector between the the silver pinout and pry down on it a lil. while prying on it you should be able to easily push it out w/ another pick or pocket screwdriver. once its out just recrimp the wire to the pinout and install it back into the map sensor connector. hope this helps.
Old Sep 2, 2003 | 05:41 PM
SOFLSOL's Avatar
Default Re: Replacing map wire in ecu harness (JayDM Honda)
Thanks a bunch. Ill try that.
thevtecnician
Oct 5, 2009 07:22 AM
Gant
May 18, 2005 08:47 PM
Ski11z
Jul 15, 2004 08:36 AM
This One
Feb 2, 2003 04:20 AM
