Manifold swap question.
I have a 96 Civic EX with an Auto tranny and I am working on an auto-->manual swap, I have gone through the threads and I know that I need to change my intake manifold and throttle body out for the manual ones as well as re-wire the IACV.
Here's where my question comes in:
I have a JDM D15b in another Civic I am using for parts and I was wondering if the intake manifold and throttle body will work. I know that I will need to keep my OBD2 injectors, is there anything else? Thanks for the help.
Re: Manifold swap question. (JShull)
I assume it should fit fine. considering the d15b is the japanese equivalent to the d16z6 and that one fits fine on all d-serious... i dont think the jdm version should be any different.
Re: (JShull)
Itll work but you might want to consider drilling your auto manifold because you could be loosing power through out the band downgrading the manifold.
Re: (JShull)
The runners and the plenium is a hell of alot bigger on the y8 then the D15B/ZC/Z6. I wish i took a picture of the z6 manifold so i could compare it but i dont have it anymore. Its kind of like the B16 manifold and the Type R. There shapped the same just the Type R is bigger everywhere.
And for the drilling youll need to find a 2 wire IAC and match it up, then drill and tap the extra hole for the 2nd screw and drill out the 2 holes for the IAC to read.
hamilton_civic
10-07-2008 04:39 PM
SOHC_civic_si
10
02-18-2008 11:08 AM
